[GRASS-dev] [GRASS GIS] #3481: m.cogo (and others most likely) fail in Grass 7 under OS X if output path contains spaces
trac at osgeo.org
Mon Jan 22 20:25:25 PST 2018
contains spaces
Reporter: fgfletcher | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.0.0
Resolution: | Keywords: path quoting, m.cogo
CPU: OSX/Intel | Platform: MacOSX
Comment (by fgfletcher):
Confirming that problem is in QGIS, not GRASS. Ran GRASS 7.2.2 directly
and m.cogo's handling of spaces in file paths works OK.
In QGIS 2.18.5 m.cogo, and others, quote input file paths, but do not
quote output file paths. A workaround is to edit the output file path in
place as displayed in the m.cogo dialog so as to include quotes. Problem
has been reported to QGIS.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3481#comment:3>
