[GRASS-dev] [GRASS GIS] #2752: t.remove: add dual-step removal as in g.remove
trac at osgeo.org
Sun Jan 28 08:28:24 PST 2018
Reporter: neteler | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.4.1
Component: Temporal | Version: svn-trunk
Resolution: | Keywords: t.remove
CPU: All | Platform: All
Comment (by veroandreo):
Replying to [comment:13 martinl]:
> What is status of this issue?
The behavior described in the ticket is still the current behavior:
* no flag set: removes the strds directly (no warning) -->> I think it
would make sense to have a WARNING as in G7:g.remove and a flag to force
the removal of strds only
* if only -r flag is set, the user gets: `ERROR: The recursive flag works
only in conjunction with the force flag: use -rf` -->> IMHO, it would be
consistent with G7:g.remove to get the list of maps that will be removed
plus a WARNING with advice to use both flags (-rf) to actually remove
strds and maps, otherwise what is the point of having a flag (-r) that
cannot be used alone?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2752#comment:14>
