[GRASS-dev] lib/python/ctypes compilation errors
Markus Neteler
neteler at osgeo.org
Sun Jan 28 09:17:39 PST 2018
On Sun, Jan 28, 2018 at 4:54 PM, Huidae Cho <grass4u at gmail.com> wrote:
> Hello,
> I'm trying to compile the trunk on a new machine and getting these errors
> when compiling lib/python/ctypes.
Could you please include the ctypes error message?
> I searched this mailing list and found
> that /usr/include/GL/gl.h.. Syntax error at '\n' is normal (?),
Apparently yes, it happens also on Fedora and elsewhere.
> but what
> about the others? Regardless of these errors, make reports No errors
> detected, so can I assume there will be no harm?
> Error: /usr/lib64/gcc/x86_64-slackware-linux/5.3.0/include/xmmintrin.h:117:
> Syntax error at '{'
Could you please add more context of the error?
best
Markus
> These headers have a similar errors with different line numbers:
> /usr/lib64/gcc/x86_64-slackware-linux/5.3.0/include/avx512bwintrin.h
> /usr/lib64/gcc/x86_64-slackware-linux/5.3.0/include/avx512fintrin.h
> /usr/lib64/gcc/x86_64-slackware-linux/5.3.0/include/avx512vlintrin.h
> /usr/lib64/gcc/x86_64-slackware-linux/5.3.0/include/avxintrin.h
> /usr/lib64/gcc/x86_64-slackware-linux/5.3.0/include/bmi2intrin.h
> /usr/lib64/gcc/x86_64-slackware-linux/5.3.0/include/emmintrin.h
> /usr/lib64/gcc/x86_64-slackware-linux/5.3.0/include/f16cintrin.h
> /usr/lib64/gcc/x86_64-slackware-linux/5.3.0/include/mm3dnow.h
> GRASS SVN: Trunk as of Jan 28, 2018
> Linux: Slackware64 14.2
> Kernel: 4.14.14
> GCC: 5.3.0
> Any ideas what's going on?
> Thanks!
> Huidae
