[GRASS-dev] [GRASS GIS] #2637: Get direction raster in clockwise degrees starting from the North
trac at osgeo.org
Mon Jan 29 01:54:42 PST 2018
Reporter: cgravelm | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.4.1
Component: Raster | Version: 7.0.0
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by hellik):
Replying to [comment:24 hellik]:
> Replying to [comment:22 mmetz]:
> >Therefore I suggest to produce zero aspect for zero slope or if slope
is < min_slope. NULL is then reserved for those cells where slope and
aspect can not be computed. This also means that when converting CCW from
East to CW from North, North must be encoded as 360 degrees, not 0
degrees.
> what about to assign -1 for cells with zero slope or slope is <
min_slope?
then North can start with 0 degrees; which is the most common use case.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2637#comment:25>
