[GRASS-dev] GRASS 7.4.0 won't compile
Markus Neteler
neteler at osgeo.org
Tue Jan 30 11:29:14 PST 2018
Hi Eric,
On Tue, Jan 30, 2018 at 8:02 PM, Eric Hutton <hutton.eric at gmail.com> wrote:
> Hi Markus
> We should definitely do this at some point. The current patches were done
> just for Mac and just for building with conda. I haven't tested them all
> that much on linux or building without conda. I'm fairly certain that, at
> this point, they may break things.
Yes, for sure we need careful testing prior to update in SVN.
> If I wanted to incorporate some of these, what is the process? Iis there
> someplace I would make a pull request (or similar)?
Yes, here:
https://trac.osgeo.org/grass/
If you don't have a login (OSGeo--ID), you can create one here:
https://www.osgeo.org/community/getting-started-osgeo/osgeo_userid/
Markus
