[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
GRASS GIS trac at osgeo.org
Tue Jul 3 12:26:05 PDT 2018
  Reporter:  guano        |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Default      |    Version:  7.0.4
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  MacOSX
Comment (by hcho):
 Not sure what's happening. Please make sure that the projection of your
 mapset is EPSG:32723.
 > g.proj -p
 -PROJ_INFO-------------------------------------------------
 name       : WGS 84 / UTM zone 23S
 datum      : wgs84
 ellps      : wgs84
 proj       : utm
 zone       : 23
 south      : defined
 no_defs    : defined
 -PROJ_EPSG-------------------------------------------------
 epsg       : 32723
 -PROJ_UNITS------------------------------------------------
 unit       : meter
 units      : meters
 meters     : 1
 and set the region correctly to the DEM.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:7>
