[GRASS-dev] [GRASS GIS] #2114: m.nviz.image does not work on Windows
GRASS GIS trac at osgeo.org
Wed Jul 4 12:18:12 PDT 2018
  Reporter:  annakrat     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.4.2
 Component:  LibOpenGL    |    Version:  svn-trunk
Resolution:               |   Keywords:  m.nviz.image
       CPU:  Unspecified  |   Platform:  All
Comment (by hcho):
 This specific issue on Linux is fixed by r72939.
 Replying to [comment:8 wenzeslaus]:
 > This now seems to be an issue on Linux as well. On Ubuntu 16.04:
 > > m.nviz.image elevation_map=elevation output=test format=ppm
 size=640,480
 > X Error of failed request:  BadValue (integer parameter out of range for
 operation)
 >   Major opcode of failed request:  154 (GLX)
 >   Minor opcode of failed request:  3 (X_GLXCreateContext)
 >   Value in failed request:  0x0
 >   Serial number of failed request:  24
 >   Current serial number in output stream:  29
 > Changing platform to all. New ticket more appropriate? New
 implementation seems to be necessary.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2114#comment:11>
