[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
GRASS GIS trac at osgeo.org
Wed Jul 4 12:42:58 PDT 2018
  Reporter:  guano        |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Default      |    Version:  7.0.4
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  MacOSX
Comment (by hellik):
 Replying to [comment:20 hcho]:
 > Hmm...
 > TIFFOpen: D:\temp\mnviz\test\elev.tif: No such file or directory.
 > TIFFOpen cannot create a new file? Permission or that folder doesn't
 exist?
 > I think this issue is different from the original one. He was able to
 write out an output file with just the header. I think you'll be able to
 see the original issue once you fix this TIFFOpen issue.
 there is no permission issue as other winGRASS modules are able to write
 to this folder.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:22>
