[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
trac at osgeo.org
Wed Jul 4 14:05:02 PDT 2018
Reporter: guano | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.0.4
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by hcho):
Replying to [comment:24 cmbarton]:
> Replying to [comment:16 hcho]:
> > Or in your m.nviz.image command, change {{{size=500,500}}} to
{{{size=512,512}}}.
> I just did this and it gives the same result, an image file with header
but no content. Same output message too.
What about changing {{{GL_TEXTURE_2D}}} to {{{GL_TEXTURE_RECTANGLE_EXT}}}
in lib/nviz/render.c? You're on MacOS, right?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:25>
