[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
trac at osgeo.org
Wed Jul 4 18:33:54 PDT 2018
Reporter: guano | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.0.4
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by guano):
I made the changes to render.c:
aglCreatePBuffer(width, height, GL_TEXTURE_RECTANGLE_EXT, GL_RGBA, 0,
&(rwin->windowId));
if (aglCreatePBuffer(width, height, GL_TEXTURE_RECTANGLE_EXT, GL_RGBA, 0,
&(rwin->windowId)) == GL_FALSE)
fprintf(stderr, "aglCreatePBuffer failed: %d %d %d\n", width, height,
aglGetError());
and tried to run with {{{size=500,500}}} and {{{size=512,512}}}
the result is the same, as well as the error message:
{{{aglCreatePBuffer failed: 500 500 10005}}}
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:27>
