[GRASS-dev] [GRASS GIS] #3602: Quick Database Switcher
trac at osgeo.org
Thu Jul 5 02:57:40 PDT 2018
Reporter: pshapley | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone:
Component: Database | Version: 7.4.0
Resolution: | Keywords:
CPU: x86-64 | Platform: All
Comment (by mmetz):
Replying to [ticket:3602 pshapley]:
Part 2:
> To take care of re-entering database connection configuration of
'db.connect' and 'dblogin' it also seems impossible to reset 'schema' and
'group' without opening the 'VAR' file and manually removing them each
time you swap databases. A simpler solution needed.
has been solved with #3601
Ticket URL: <https://trac.osgeo.org/grass/ticket/3602#comment:1>
