[GRASS-dev] Compiler error in /lib/calc
Vaclav Petras
wenzeslaus at gmail.com
Thu Jul 5 14:54:24 PDT 2018
[Response to Re: [GRASS-dev] grass-dev Digest, Vol 149, Issue 11]
Hi Michael,
I'm not able to reproduce this issue on Linux with clang (which is used on
Mac) even with more strict compiler settings:
clang -O2 -fno-common -Wall -pedantic -Wextra ...
Since both "installation/dist" and source paths appear in the command line,
even the error message says the function is there (actually, already in the
installed/dist path), the includes were not changed (in r72940), and the
errors are only related to the newly added functions (f_ceil, f_floor), I
suggest just updating and recompiling again and making sure that two source
codes or installations are not tangled together.
For the record, this is not related to m.nviz.image changes. It might be
related to r72940 r.mapcalc: +ceil, +floor (fixes #769).
Best,
Vaclav
On Thu, Jul 5, 2018 at 5:14 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> To try and test the fix to m.nviz.image, I just now did for trunk:
> Make distclean
> Svn update
> Configure (no problem)
> Compile
> I got a compiler error in /lib/calc (error below)
> Is this due to the recent fix?
> I also tried it with a completely new version of trunk downloaded and got
> the same errors.
> Michael
> ========== error ==========
> Errors in:
> /Users/cmbarton/grass_source/trunk/lib/calc
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Thu Jul 5 13:47:36 MST 2018
> make: *** [default] Error 1
> cmb-imaccsdc:trunk cmbarton$ cd /Users/cmbarton/grass_source/
> trunk/lib/calc
> cmb-imaccsdc:calc cmbarton$ make
> /Applications/GRASS-7.5.app/Contents/Resources/bin/clang
> -I/Applications/GRASS-7.5.app/Contents/Resources/include -g -O2
> -fno-common -I/Applications/GRASS-7.5.app/Contents/Resources/include
> -I/Users/cmbarton/grass_source/trunk/dist.x86_64-apple-darwin17.6.0/include
> -DPACKAGE=\""grasslibs"\" -I/Users/cmbarton/grass_
> -DRELDIR=\"lib/calc\" -o OBJ.x86_64-apple-darwin17.6.0/function.o -c
> function.c
> function.c:14:22: error: use of undeclared identifier 'f_ceil'
> {"ceil", c_unop, f_ceil},
> function.c:15:23: error: use of undeclared identifier 'f_floor'; did you
> mean 'f_float'?
> {"floor", c_unop, f_floor},
> f_float
> /Applications/GRASS-7.5.app/Contents/Resources/include/grass/defs/calc.h:63:15:
> note: 'f_float' declared here
> extern func_t f_float;
> 2 errors generated.
> make: *** [OBJ.x86_64-apple-darwin17.6.0/function.o] Error 1
> ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
> www: http://csdc.asu.edu, http://shesc.asu.edu
> http://www.public.asu.edu/~cmbarton
> On 7/5/18, 12:00 PM, "grass-dev on behalf of
> grass-dev-request at lists.osgeo.org" <grass-dev-bounces at lists.osgeo.org on
> behalf of grass-dev-request at lists.osgeo.org> wrote:
> Date: Thu, 05 Jul 2018 03:23:44 -0000
> From: "GRASS GIS" <trac at osgeo.org>
> To: undisclosed-recipients: ;
> Cc: grass-dev at lists.osgeo.org
> Subject: Re: [GRASS-dev] [GRASS GIS] #2998: m.nviz.image fails with X
> Error BadValue integer parameter out of range for operation
> Message-ID: <060.01ef0c91d1c90d09d0aa6600166f8b24 at osgeo.org>
> Content-Type: text/plain; charset="utf-8"
> #2998: m.nviz.image fails with X Error BadValue integer parameter out
> of range for
> operation
> Reporter: wenzeslaus | Owner: grass-dev@…
> Type: defect | Status: closed
> Priority: normal | Milestone: 7.2.4
> Component: LibOpenGL | Version: svn-trunk
> Resolution: fixed | Keywords: m.nviz.image, NVIZ, 3D, GLX,
> | X_GLXCreateContext, g.gui.animation
> CPU: x86-64 | Platform: Linux
> Comment (by hcho):
> Oh! I'm on Linux (Slackware 14.2). Is there a way to reproduce your
> issue?
> Any sample data set and command line? Maybe, it was related to my
> mistake
> in write_img.c, which is just fixed in r72951?
> Ticket URL: <https://urldefense.proofpoint.com/v2/url?u=https-
> 3A__trac.osgeo.org_grass_ticket_2998-23comment-3A19&d=DwIGaQ&c=l45AxH-
> kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6n
> fT1XEEEtR0&m=dAPexcceMdlawW6E7rSolX7s8mY6Jql0drLwOwoKKfc&s=
> 5uNzqfWlMr40jdzC0Ny-QDAl8hVGhUxCxrhXgMOr2gQ&e=>
> GRASS GIS <https://urldefense.proofpoint.com/v2/url?u=https-
> 3A__grass.osgeo.org&d=DwIGaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_
> 2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=
> RZLKiXtG8s2xqATPclFfuTwSQ6hpancGROIW78AqtI4&e=>
> grass-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180705/3b720297/attachment-0001.html>
