[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
trac at osgeo.org
Sat Jul 7 23:54:21 PDT 2018
Reporter: guano | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.0.4
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by hcho):
Replying to [comment:28 hellik]:
> Replying to [comment:21 hcho]:
> > Please try r72948.
> tested with
> GRASS version: 7.5.svn
> GRASS SVN revision: r72959
> Build date: 2018-07-06
> Build platform: x86_64-w64-mingw32
> GDAL: 2.2.4
> PROJ.4: 4.9.3
> GEOS: 3.5.0
> SQLite: 3.17.0
> Python: 2.7.14
> wxPython: 2.8.12.1
> Platform: Windows-10-10.0.17134 (OSGeo4W)
> ppm and tif can't be opened.
> DEBUG=3 output of the cmd, tif and ppm attached
Hmm... The size of the ppm is 6618224*0. OK, glViewport never gets called
unless you resize the viewport. I think omitting glViewport is
implementation dependent. Please try the attached patch
(lib/nviz/render.c).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:29>
