[GRASS-dev] [GRASS GIS] #3602: Quick Database Switcher
trac at osgeo.org
Sun Jul 8 23:39:23 PDT 2018
Reporter: pshapley | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone:
Component: Database | Version: 7.4.0
Resolution: | Keywords:
CPU: x86-64 | Platform: All
Comment (by mmetz):
Replying to [comment:2 mlennert]:
> Markus has answered and solved the specific schema + group issues, but
from the OP it sounds as if one needs to change db.connect settings for
the use of v.out.postgis. AFAICT, this is not the case: there is no need
to mess with db.connect to use v.out.postgis. If this were the case, I
would consider this as a bug, as these settings should only determine
default attribute backend settings in a mapset.
There is a bug in v.out.postgis: it does not copy tables from input to
output, it copies only dblinks from input to output which only works if
input (GRASS) and output (PostGIS) use the same driver and database for
attributes. In theory this could be easily fixed by copying tables.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3602#comment:3>
