[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
trac at osgeo.org
Mon Jul 9 13:44:27 PDT 2018
Reporter: guano | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.0.4
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by hcho):
Replying to [comment:47 cmbarton]:
> I've attached the output in ppm form after re-enabling line 221. I reset
g.region (g.region rast=elevation) and it is the same.
Hmm.. Please enable line 221 (this line works as expected. reporting the
correct viewport size).
Test 1: line 148. change GL_TEXTURE_2D to GL_TEXTURE_RECTANGLE_EXT
Test 2: Keep GL_TEXTURE_2D in line 148 and change size=640,480 to
size=512,512 (power of 2 for GL_TEXTURE_2D).
I know the original reporter already tried these, but without line 221.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:48>
