[GRASS-dev] [GRASS GIS] #3606: m.nviz.image produces a screenshot
GRASS GIS trac at osgeo.org
Sun Jul 15 08:44:48 PDT 2018
  Reporter:  epifanio  |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  major     |  Milestone:
 Component:  Display   |    Version:  svn-trunk
Resolution:            |   Keywords:
       CPU:  x86-64    |   Platform:  Linux
Comment (by epifanio):
 Applied the patch on latest trunk rev. num.: 72990
 print out the following output:
 GRASS 7.5.svn (nc_basic_spm_grass7):~ > m.nviz.image
 elevation_map=elevation output=elev perspective=15 --o
 Loading raster map <elevation at PERMANENT>...
  100%
  100%
 Translating colors from raster map <elevation at PERMANENT>...
  100%
 buffer: both
 buffer: both
 buffer: both
 buffer: both
 buffer: both
 buffer: both
 buffer: both
 buffer: swap
 buffer: both
 m.nviz.image complete. File <elev.ppm> created.
 My grass_trunk is configured without X11 support:
 GRASS is now configured for:  x86_64-pc-linux-gnu
   Source directory:           /home/epinux/dev/grass7_trunk
   Build directory:            /home/epinux/dev/grass7_trunk
   Installation directory:     ${prefix}/grass-7.5.svn
   C compiler:                 gcc -g -O2
   C++ compiler:               c++ -g -O2
   Building shared libraries:  yes
   OpenGL platform:            X11
   MacOSX application:         no
   MacOSX architectures:
   MacOSX SDK:
   BLAS support:               yes
   BZIP2 support:              yes
   C++ support:                yes
   Cairo support:              yes
   DWG support:                no
   FFTW support:               yes
   FreeType support:           yes
   GDAL support:               yes
   GEOS support:               yes
   LAPACK support:             yes
   Large File support (LFS):   yes
   libLAS support:             yes
   MySQL support:              no
   NetCDF support:             yes
   NLS support:                no
   ODBC support:               yes
   OGR support:                yes
   OpenCL support:             no
   OpenGL support:             yes
   OpenMP support:             yes
   PDAL support:               yes
   PNG support:                yes
   POSIX thread support:       yes
   PostgreSQL support:         yes
   Readline support:           yes
   Regex support:              yes
   SQLite support:             yes
   TIFF support:               yes
   X11 support:                no
   Zstandard support:          yes
   using old PROJ 4 API
Ticket URL: <https://trac.osgeo.org/grass/ticket/3606#comment:4>
