[GRASS-dev] [GRASS GIS] #3606: m.nviz.image produces a screenshot
trac at osgeo.org
Tue Jul 17 17:11:00 PDT 2018
Reporter: epifanio | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Display | Version: svn-trunk
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by hcho):
Replying to [comment:15 epifanio]:
> Double checking I've the right changes applied to the right files, here
is a gist of the previous files:
> https://gist.github.com/c6a7cb6019f2347add44f2dc6b35f4c7
> With this configuration, I do have a proper PPM rendering the elevation
surface correctly.
I'm confused. Do you mean that the files in the gist work for you? That's
basically trunk + debug outputs.
In your last test, you drew to the front buffer without swapping
(different from your gist). Did they both work for you?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3606#comment:16>
