[GRASS-dev] [GRASS GIS] #3604: errors running r.category.trim
GRASS GIS trac at osgeo.org
Wed Jul 18 22:51:37 PDT 2018
  Reporter:  Alister      |      Owner:  pvanbosgeo
      Type:  defect       |     Status:  assigned
  Priority:  normal       |  Milestone:
 Component:  Addons       |    Version:  7.4.0
Resolution:               |   Keywords:  r.category.trim
       CPU:  Unspecified  |   Platform:  MSWindows 2K
Changes (by neteler):
 * keywords:   => r.category.trim
 * platform:  Unspecified => MSWindows 2K
Comment:
 Replying to [comment:5 Alister]:
 > Yes it works now, thanks.
 > I'm not sure how you meant to reinstall the addon though - using
 g.extension in the grass gui just reinstalls the old version, [...]
 FYI: Since you are on Windows g.extension fetches addons which are
 generated daily (but not in real time) on the Windows-build host. This
 happens AFAIK once a day, so give it a 24s to show up online. (in your
 case here fine that you downloaded the update directly from trac since it
 is the addon is written in Python not requiring true compilation).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3604#comment:6>
