[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
trac at osgeo.org
Wed Jul 25 07:03:53 PDT 2018
Reporter: guano | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.0.4
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by hcho):
Replying to [comment:84 hcho]:
> Replying to [comment:83 guano]:
> > It works!
> > The attachments I just added (Screenshot.jog and
nviz_output_working.jpg) show the 3D image setup and the output.
> > Many thanks for the work on this!
> Yay! Thanks for testing. Could you please test other cases too just to
make sure that only this setup works?
> 1. AGL without FBO: current trunk, doesn't work
> 2. AGL with FBO: Add {{{#define OPENGL_AGL 1}}} in those four files
(OPENGL_AGL & OPENGL_FBO); {{{./configure; make clean && make}}}
> 3. CGL without FBO: Remove {{{#define OPENGL_FBO 1}}} from the above
files (no OPENGL_FBO, no OPENGL_AGL); {{{./configure; make clean &&
make}}}
> 4. CGL with FBO: (OPENGL_FBO, no OPENGL_AGL) You just confirmed that it
works.
> Since AGL is deprecated and only supports 32bit, we should go with case
4 at least for the Mac. The only problem with FBO is that the nviz and
ogsf libraries will be offscreen rendering only without direct rendering
to application windows (default framebuffer provided by a windowing system
like X11, Aqua, and GDI32). Right now, no other modules use nviz & ogsf
for direct rendering and wxGUI & wxPython provide that capability, so I
don't see any major issues at this moment.
For this testing, please make sure to {{{#define}}} at the very beginning
of each file before any {{{#if defined()}}}.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:86>
