[GRASS-dev] SSL Certificate
Markus Neteler
neteler at osgeo.org
Fri Jul 27 22:22:58 PDT 2018
Hi Huidae, all,
(CC lists)
Huidae Cho <grass4u at gmail.com> schrieb am Sa., 28. Juli 2018, 03:20:
> Hi Markus,
> Not sure if you noticed this. I'm getting an SSL certificate error when
> accessing grass.osgeo.org.
> grass.osgeo.org uses an invalid security certificate.
> The certificate is only valid for the following names:
> mapserver.org, www.mapserver.org
> Error code: SSL_ERROR_BAD_CERT_DOMAIN
> Is it just me?
> Huidae
> Huidae Cho, Ph.D., PE, M.ASCE, CFM, GISP
> Open Source GIS Developer, GRASS GIS Development Team
I also realized that yesterday and escalated it to OSGeo-SAC.
In fact, a SAC member had messed the certificate accidentally up and fixed
it later.
Please report of you find any OSGeo site still causing troubles.
Best
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180728/63784e8f/attachment.html>
