[GRASS-dev] [GRASS GIS] #3608: v.what.vect: dmax in degree?
GRASS GIS trac at osgeo.org
Sat Jul 28 11:30:17 PDT 2018
 Reporter:  lrntct  |      Owner:  grass-dev@…
     Type:  defect  |     Status:  new
 Priority:  normal  |  Milestone:
Component:  Vector  |    Version:  7.4.0
 Keywords:          |        CPU:  All
 Platform:  All     |
 The dmax option of v.what.vect is described as being in map units.
 However, it seems to not be the case, art least for lat/lon locations.
 Consider the attached example:
 The point is largely within 10 degrees of the polygon, but it will not be
 included in a call to v.what.vect with dmax=10.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3608>
