[GRASS-dev] segmentation fault with temporal commands
Veronica Andreo
veroandreo at gmail.com
Sat Jul 28 14:40:02 PDT 2018
Hi devs,
I get "segmentation fault" when running temporal commands, i.e., t.list,
t.info, t.create, t.register (haven't tested them all). However, the
command works as expected. It's just that I get the message "Segmentation
fault (core dumped)" whenever I run a temporal command. I use grass trunk
r73007 in Fedora 28.
Here I paste the final part of the strace output (dunno if that's the part
useful):
strace t.info LST_Day_monthly
stat("/home/veroandreo/grassdata/nc_spm_08_grass7/modis_lst/tgis/sqlite.db",
{st_mode=S_IFREG|0644, st_size=585728, ...}) = 0
close(3) = 0
getpid() = 7519
wait4(7527, 0x7fff654f8644, WNOHANG, NULL) = 0
write(5, "\0\0\0\17\200\2]q\1U\4STOPq\2a.", 19) = 19
getpid() = 7519
wait4(7527, 0x7fff654f83d4, WNOHANG, NULL) = 0
select(0, NULL, NULL, NULL, {tv_sec=0, tv_usec=1000}) = ? ERESTARTNOHAND
(To be restarted if no handler)
--- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=7527,
si_uid=1000, si_status=1, si_utime=0, si_stime=0} ---
select(0, NULL, NULL, NULL, {tv_sec=0, tv_usec=0}) = 0 (Timeout)
wait4(7527, [{WIFEXITED(s) && WEXITSTATUS(s) == 1}], WNOHANG, NULL) = 7527
close(5) = 0
futex(0x55b0471463a0, FUTEX_WAIT_BITSET_PRIVATE|FUTEX_CLOCK_REALTIME, 0,
NULL, 0xffffffff) = 0
getpid() = 7519
wait4(7528, 0x7fff654f8644, WNOHANG, NULL) = 0
write(7, "\0\0\0\t\200\2]q\1K\0a.", 13) = 13
kill(7528, SIGTERM) = 0
close(7) = 0
getpid() = 7519
wait4(7528, [{WIFSIGNALED(s) && WTERMSIG(s) == SIGTERM}], 0, NULL) = 7528
--- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_KILLED, si_pid=7528,
si_uid=1000, si_status=SIGTERM, si_utime=0, si_stime=0} ---
rt_sigaction(SIGINT, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER,
sa_restorer=0x7f78a8694fc0}, {sa_handler=0x7f78a8a2c880, sa_mask=[],
sa_flags=SA_RESTORER, sa_restorer=0x7f78a8694fc0}, 8) = 0
munmap(0x7f78a8f16000, 32) = 0
close(9) = 0
munmap(0x7f78a8f17000, 32) = 0
close(6) = 0
close(8) = 0
futex(0x7f7897973574, FUTEX_WAKE_PRIVATE, 2147483647) = 0
futex(0x7f78966421e4, FUTEX_WAKE_PRIVATE, 2147483647) = 0
munmap(0x7f787bda5000, 33554496) = 0
munmap(0x7f7879da4000, 33554496) = 0
munmap(0x7f7877da3000, 33554496) = 0
munmap(0x7f7875da2000, 33554496) = 0
munmap(0x7f7873da1000, 33554496) = 0
munmap(0x7f7871da0000, 33554496) = 0
munmap(0x7f786fd9f000, 33554496) = 0
munmap(0x7f786dd9e000, 33554496) = 0
--- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0x7f787bda5008}
+++ killed by SIGSEGV (core dumped) +++
Segmentation fault (core dumped)
best,
Vero
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180728/13db8aa0/attachment.html>
