[GRASS-dev] Avoid the addition of @mymapset in output map name
Roberta Fagandini robifagandini at gmail.com
Fri Jun 1 04:44:25 PDT 2018
2018-05-31 15:08 GMT+02:00 Roberto Marzocchi <roberto.marzocchi at gmail.com>:
> 2018-05-29 14:09 GMT+02:00 Markus Metz <markus.metz.giswork at gmail.com>:
>> Hi Roberta,
>> On Tue, May 29, 2018 at 1:41 PM, Moritz Lennert <
>> mlennert at club.worldonline.be> wrote:
>> > Hi Roberta,
>> > Le Tue, 29 May 2018 13:16:48 +0200,
>> > Roberta Fagandini <robifagandini at gmail.com> a écrit :
>> > > Hi all!
>> > > I'm working on the GUI of my module for clouds and shadows detection
>> > > in Sentinel 2 images  (GSoC 2018 project) and I have some trouble
>> > > with the automatic addition of the mapset name in the output maps.
>> > > I have several input bands imported in GRASS that I convert into float
>> > > value and rescale using r.mapcalc, each output map should be
>> > > automatically named with the inputs band name and a suffix (e.g.
>> > > input: nir - output: nir_float).
>> > > When I run the script using the GUI I have an error due to the @mapset
>> > > automatically added to the output map name (e.g. nir at mymapset_float).
>> > > At the moment, I solved the problem with a replace() function but I'm
>> > > not sure this can be the best solution, do you have any hint?
>> > A classic solution that you will find in many scripts is using split():
>> > mapname_without_mapset = mapname_with_mapset.split('@')[0]
>> there is find_file() in lib/python/script/core.py with returns a
>> dictionary of keys/values including the name without mapset
>> Markus M
> With find_file it should work also for maps in different mapset.
> Roberta can you test it?
> R
Yes, it works!
Thank you all for your help!
Roberta
>> > Moritz
>> > _______________________________________________
>> > grass-dev mailing list
>> > grass-dev at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180601/9392c873/attachment-0001.html>
