[GRASS-dev] [GRASS GIS] #3570: g.remove dialog does not allow user to select map(s)
GRASS GIS trac at osgeo.org
Fri Jun 1 15:12:52 PDT 2018
 Reporter:  cmbarton         |      Owner:  grass-dev@…
     Type:  defect           |     Status:  new
 Priority:  normal           |  Milestone:
Component:  Default          |    Version:  svn-trunk
 Keywords:  g.remove, wxgui  |        CPU:  Unspecified
 Platform:  Unspecified      |
 Weirdly, the map selection dialog only gives "no selectable item"
 regardless of whether a map type is selected. This only seems a problem in
 7.5 svn.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3570>
