[GRASS-dev] a proposal to rename "location"
Vaclav Petras wenzeslaus at gmail.com
Sat Jun 2 08:17:19 PDT 2018
On Fri, Jun 1, 2018 at 9:33 PM, Nikos Alexandris <nik at nikosalexandris.net>
wrote:
> Would think of SRS instead of CRS, so as to be in line with GDAL's
> terminology?
CRS versus SRS: Here are the definitions from OGC Glossary:
coordinate reference system (CRS):
A coordinate system that has a reference to the Earth. Consists of a
coordinate system and a datum.
spatial reference system:
As defined in the OpenGIS Abstract Specification Topic 2 and ISO 19111.
Position on or near the Earth's surface can be described by spatial
reference systems. These are of two basic types: those using coordinates;
and those based on geographic identifiers (for example postal addresses,
administrative areas). Spatial referencing by geographic identifiers is
defined in ISO 19112, Geographic information - "Spatial referencing by
geographic identifiers." The subject matter of The OpenGISĀ® Abstract
Specification Topic 2: "Spatial Referencing by Coordinates" is spatial
referencing by coordinates. Source: The OpenGISĀ® Abstract Specification
http://www.opengis.org/techno/abstract/02-102.pdf
http://www.opengeospatial.org/ogc/glossary/c
http://www.opengeospatial.org/ogc/glossary/s
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180602/ddb32b51/attachment-0001.html>
