[GRASS-dev] [GRASS GIS] #3572: v.vect.stats creates cat & cat_ then fails
trac at osgeo.org
Mon Jun 4 13:50:01 PDT 2018
Reporter: simondedman | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.4.0
Resolution: | Keywords:
CPU: x86-64 | Platform: MSWindows CygWin
Comment (by simondedman):
Thanks Markus.
Am I right in thinking that QGis devs would have to code this switch into
the GUI as an option? As it stands it seems the only call to v.out.ogr is
to select the type, with a dropbown field that doesn't allow switches.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3572#comment:2>
