[GRASS-dev] [GRASS GIS] #3572: v.vect.stats creates cat & cat_ then fails
GRASS GIS trac at osgeo.org
Mon Jun 4 14:16:21 PDT 2018
  Reporter:  simondedman  |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Default      |    Version:  7.4.0
Resolution:               |   Keywords:
       CPU:  x86-64       |   Platform:  MSWindows CygWin
Comment (by simondedman):
 Not make it an option i.e. general users probably don't need the cat
 column and therefore the -s switch could be on by default at all times?
 (Just want to make sure I understand correctly!)
 What does the -m switch do? I was looking for v.out.ogr info in the
 v.vect.stats help & code but I guess I'm looking in the wrong places.
 Thanks again.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3572#comment:4>
