[GRASS-dev] [GRASS GIS] #3573: Save current working directory in wxGUI workspace and use it
trac at osgeo.org
Wed Jun 6 07:29:00 PDT 2018
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 8.0.0
Component: Startup | Version: unspecified
Keywords: workspace, recent, startup, wxGUI | CPU: Unspecified
Platform: Unspecified |
When user changes current working directory in GUI, saves workspace, and
reopens the same workspace, everything is there (especially after we have
#2604) but the current working directory is the system default.
The current working directory should be stored in the workspace and then
applied when starting.
It is not clear to me if only the GUI work dir should be changed or if
also the command line should be changed (if it is during startup, it
should be possible to change it for command line as well - considering
that we need to read the workspace file for #2604).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3573>
