[GRASS-dev] [GRASS GIS] #3575: Associate database/location/mapset with workspace file
trac at osgeo.org
Wed Jun 6 10:08:19 PDT 2018
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 8.0.0
Component: Startup | Version: unspecified
Keywords: workspace, location, wxGUI, | CPU: Unspecified
startup, save, load |
Platform: All |
Save the database/location/mapset in a workspace file. When workspace is
loaded, it should switch it to the given database/location/mapset as with
''Settings > GRASS working environment > ...''
Before the switch, it should check if the mapset dir exist and if it is a
mapset. When that fails (data moved, using different computer, ...), offer
user option to not change workspace (a "Cancel" button) or open the
workspace without the change of mapset (the current behavior) or let user
provide the right database/location/mapset.
Additionally, upon loading, we could check if the layers in Layer Manager
exist. (But that might be solved in some other way in GUI - this
information is currently not conveniently accesible - only when adding a
layer and rendering.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3575>
