[GRASS-dev] Should a g.rename action be recorded in a map's history?
Nikos Alexandris nik at nikosalexandris.net
Thu Jun 7 09:01:26 PDT 2018
Dear developers,
would you consider as important a renaming of a map, such that it should
be recorded in its history?
After renaming,
- a vector map, it's likely possible to trace back its origin from its
  history (v.info -h)
- a raster map, that has been created with `r.mapcalc`, for example, there
is no way to tell where it comes from -- other than the command history
or guessing from the expression used that is recorded in its history.
If yes, should I file a ticket?
Thank you, Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180607/d5f336c1/attachment.sig>
