[GRASS-dev] [EXTERNAL] [GRASS GIS] #3560: r.in.lidar: error to open valid LAZ file
Newcomb, Doug
doug_newcomb at fws.gov
Thu Jun 7 13:17:11 PDT 2018
On a related note, I tried compiling liblas1.8.1 ( current version) on
Ubuntu 18.04 last night and I get a lot of errors out of the box that seem
to be related to compiler version. Will need to set up a virtual 16.04 box
for the short term.
Doug
On Wed, May 9, 2018 at 4:14 PM, Newcomb, Doug <doug_newcomb at fws.gov> wrote:
> On Wed, May 9, 2018 at 4:02 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Wed, May 9, 2018 at 9:37 PM, Newcomb, Doug <doug_newcomb at fws.gov>
>> wrote:
>> > On Wed, May 9, 2018 at 3:21 PM, Markus Neteler <neteler at osgeo.org>
>> wrote:
>> >> Doug,
>> >> On Wed, May 9, 2018 at 9:17 PM, Newcomb, Doug <doug_newcomb at fws.gov>
>> >> wrote:
>> >> > Markus,
>> >> > Liblas reads LAS version 1.2 , which is limited to 4.2 billion
>> points.
>> >> I see. But "count" states 297.683.873 which is way less points?
>> > Good question
>> >> > You have to compile liblas with an older version of laszip .
>> >> Uhm, why an _older_ version?
>> > The API to LASzip changed with version 3. I use LASzip 2.2.0 compiled
>> with
>> > liblas from 2013 and have no problems so far. https://laszip.org/
>> The most
>> > recent version of 3 was for version 1.4 of the LAS spec.
>> > You need to compile current pdal and current liblas with different
>> versions
>> > of the Laszip library .
>> On that machine is PDAL-1.7.0 (wit patches) which requires laszip 3.2.x.
>> So, to compile liblas with an older laszip would be tricky.
> On the machine I am using for this , I have compiled the old laszip as
> the system laszip library and compile but do not install the newer one. I
> then point pdal to the directory with the newer version when compiling it.
> So far, that seems to work.
>> > pdal used to output version 1.2 of las data by default . I t worked
>> fine for
>> > me at version 1.6 . I have not checked if that is the case with version
>> > 1.7.1 . 1.7 had a bug which required a quick bugfix to 1.7.1, by the
>> way. (
>> > I do not recall the bug off of the top of my head.)
>> The solution would be the implementation of r.in.pdal:
>> https://trac.osgeo.org/grass/ticket/3515
>> to get rid of liblas which is not developed any more.
>> And/or package laz-perf.... sigh, so many hours already spent on
>> packaging...
>> Markus
> Doug
> Doug Newcomb
> USFWS
> 551F Pylon Dr
> Raleigh, NC
> 919-856-4520 ext. 14 doug_newcomb at fws.gov
> *NOTE: This email correspondence and any attachments to and from this
> sender is subject to the Freedom of Information Act (FOIA) and may be
> disclosed to third parties.*
Doug Newcomb
USFWS
551F Pylon Dr
Raleigh, NC
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180607/2cb12d5b/attachment.html>
