[GRASS-dev] [GRASS GIS] #3570: g.remove dialog does not allow user to select map(s)
GRASS GIS trac at osgeo.org
Sat Jun 9 09:22:24 PDT 2018
  Reporter:  cmbarton     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Default      |    Version:  svn-trunk
Resolution:               |   Keywords:  g.remove, wxgui
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by cmbarton):
 I don't quite understand the comment 2. Does that mean the problem is
 fixed in 72786 or caused by 72786? The referenced ticket is this one here.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3570#comment:3>
