[GRASS-dev] [GRASS GIS] #3585: Don't require -c for --tmp-location
trac at osgeo.org
Sat Jun 9 19:02:35 PDT 2018
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 8.0.0
Component: Startup | Version: svn-trunk
Keywords: init, grass.py, location, tmp- | CPU: Unspecified
location, CRS, CLI, gsoc2018 |
Platform: Unspecified |
With this ticket, I'm seeking feedback for designing interface for
creating temporary locations from command line.
With `--tmp-location` (#3537, r72790), CRS needs to be specified using the
`-c` flag:
grass7 -c EPSG:3358 --tmp-location --exec g.proj -p
Without `--tmp-location`, `-c` is used to tell GRASS to create a new
location or mapset. However, with `--tmp-location` GRASS knows that it
needs to create a new location, so `-c` is required here to only specify
the coordinate system. Thus, `--tmp-location` could itself require a value
to be provided, so that the syntax would become:
grass7 --tmp-location EPSG:3358 --exec g.proj -p
Usage would look like (new):
grass75 --tmp-location [geofile | EPSG] --exec EXECUTABLE [EPARAM]...
Instead of (old):
grass75 -c [geofile | EPSG] --tmp-location --exec EXECUTABLE [EPARAM]...
Or concisely with a reference:
grass75 [-h | -help | --help | --h] [-v | --version]
[-c [CRS]] [-e] [-f]
[-text | -gtext | -gui] [--config param]
[[[GISDBASE/]LOCATION_NAME/]MAPSET]
grass75 [FLAG]... GISDBASE/LOCATION_NAME/MAPSET --exec EXECUTABLE
[EPARAM]...
grass75 --tmp-location CPARAM --exec EXECUTABLE [EPARAM]...
CRS nothing or geofile or
EPSG:code[:datum_trans]
CRS (or written like:) [geofile | EPSG:code[:datum_trans]]
EXECUTABLE GRASS module, script or any other
executable
EPARAM parameters of the executable
FLAG standard flags
# Alternatives to CRS are SRS and CPARAM (like EPARAM).
Note 1: The current parsing does not care about order, so e.g. `grass7
--tmp-location EPSG:3358 -c --exec...` is possible now. This should be
probably fixed in the future (e.g. 8.0.0 release). (It is not specified in
the manual, so the current behavior can fixed/dropped any time.)
Note 2: This is part of making the command line as short as possible, so
it might be strange that the `--tmp-location` flag is long, but that's a
topic for another ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3585>
