[GRASS-dev] [EXTERNAL] New GRASS addon i.sentinel.mask is now available (GSoC 2018 project)
Doug Newcomb doug_newcomb at fws.gov
Wed Jun 13 09:33:19 PDT 2018
Trying to reinstall and getting:
 Downloading precompiled GRASS Addons <i.sentinel.mask>...
ERROR: Extension <i.sentinel.mask> not found
Either Roberta has started looking at it  already or it is a local
problem.  I will try to chase it down here before I go on vacation.  Either
way, I appreciate the work Roberta continues to put into this.  Thanks
again Roberta!
Doug
On Wed, Jun 13, 2018 at 12:17 PM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Wed, Jun 13, 2018 at 12:04 PM, Doug Newcomb <doug_newcomb at fws.gov>
> wrote:
>> Looks like it is set up to require administrative access by default?
>> ERROR: Unable to create 'C:\Program Files\GRASS GIS 7.4.0\docs\rest':
>> [Error 5] Access is denied: 'C:\\Program Files\\GRASS GIS 7.4.0\\docs\\rest'
> Are you sure it is not a local problem? Works fine with latest trunk on
> Linux:
> grass --tmp-location -c --exec g.extension i.sentinel.mask
> Likely not related to i.sentinel.mask. Please, try different module.
Doug Newcomb
USFWS
551F Pylon Dr
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
*NOTE: This email correspondence and any attachments to and from this
sender is subject to the Freedom of Information Act (FOIA) and may be
disclosed to third parties.*​
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180613/29afa51e/attachment.html>
