[GRASS-dev] [EXTERNAL] New GRASS addon i.sentinel.mask is now available (GSoC 2018 project)
Roberta Fagandini robifagandini at gmail.com
Thu Jun 14 01:01:24 PDT 2018
Hi Doug!
Thank you!!
I have just tested the installation on Windows and, as Helmut written, I
confirm that it works today!
If you test the module please do not hesitate to send me your feedback
about the results, usability or whatever.
Thanks!
Roberta
2018-06-13 18:33 GMT+02:00 Doug Newcomb <doug_newcomb at fws.gov>:
> Trying to reinstall and getting:
>  Downloading precompiled GRASS Addons <i.sentinel.mask>...
> ERROR: Extension <i.sentinel.mask> not found
> Either Roberta has started looking at it  already or it is a local
> problem.  I will try to chase it down here before I go on vacation.  Either
> way, I appreciate the work Roberta continues to put into this.  Thanks
> again Roberta!
> Doug
> On Wed, Jun 13, 2018 at 12:17 PM Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
>> On Wed, Jun 13, 2018 at 12:04 PM, Doug Newcomb <doug_newcomb at fws.gov>
>> wrote:
>>> Looks like it is set up to require administrative access by default?
>>> ERROR: Unable to create 'C:\Program Files\GRASS GIS 7.4.0\docs\rest':
>>> [Error 5] Access is denied: 'C:\\Program Files\\GRASS GIS 7.4.0\\docs\\rest'
>> Are you sure it is not a local problem? Works fine with latest trunk on
>> Linux:
>> grass --tmp-location -c --exec g.extension i.sentinel.mask
>> Likely not related to i.sentinel.mask. Please, try different module.
> Doug Newcomb
> USFWS
> 551F Pylon Dr
> <https://maps.google.com/?q=551F+Pylon+Dr+Raleigh,+NC&entry=gmail&source=g>
> Raleigh, NC
> 919-856-4520 ext. 14 doug_newcomb at fws.gov
> *NOTE: This email correspondence and any attachments to and from this
> sender is subject to the Freedom of Information Act (FOIA) and may be
> disclosed to third parties.*​
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180614/5f89109d/attachment.html>
