[GRASS-dev] New GRASS addon i.sentinel.mask is now available (GSoC 2018 project)
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Thu Jun 14 01:55:36 PDT 2018
Hi Roberta,
What about topographic correction (i.topo.corr [1])?
Should that be run before as well?
I would assume it has some impact on shadow detection in steeper terrain…
Cheers
Stefan
1: https://grass.osgeo.org/grass74/manuals/i.topo.corr.html
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of Roberta Fagandini
Sent: torsdag 14. juni 2018 10:29
To: Moritz Lennert <mlennert at club.worldonline.be>
Cc: GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] New GRASS addon i.sentinel.mask is now available (GSoC 2018 project)
Hi Moritz!
2018-06-14 10:03 GMT+02:00 Moritz Lennert <mlennert at club.worldonline.be<mailto:mlennert at club.worldonline.be>>:
On 13/06/18 17:35, Roberta Fagandini wrote:
Hi all!
The first version of i.sentinel.mask is now available and can be installed from the official svn repository.
i.sentinel.mask is a module for cloud and shadow masks computation and it is the first step of my GSoC project.
Thank you, Roberta. Great job !
Thank you!
One question: ISTR that you mentioned that the input to this module has to be atmospherically corrected images, i.e. land surface reflectance. Is this true ? If yes, then this needs to be mentioned in the man page.
Yes, it's true! I'm going to add it.
Roberta
Moritz
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180614/58e7b0ce/attachment-0001.html>
