[GRASS-dev] non-zero return code -11 from v.in.ogr in python script
Markus Metz
markus.metz.giswork at gmail.com
Thu Jun 14 06:17:14 PDT 2018
Hi Stefan,
On Thu, Jun 14, 2018 at 9:05 AM, Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> Hi Markus,
> Thanks for the reply.
> Unfortunately, the problem only occurs on the box with installation based
on UbuntuGIS-unstable packages. All self-compiled installations don't have
this problem with v.in.ogr...
You could report to the package maintainer and just use a self-compiled
installation. If the self-compiled installations run fine, it does not seem
to be a problem of GRASS.
Markus M
> So, I hope the grass-core-dbgsym and grass-dev-dbgsym packages provide
this functionality as well…
> I`ll post again if/when I find out more…
> Cheers
> Stefan
> ________________________________
> From: Markus Metz <markus.metz.giswork at gmail.com>
> Sent: Wednesday, June 13, 2018 12:27:03 PM
> To: Stefan Blumentrath
> Cc: GRASS developers list (grass-dev at lists.osgeo.org)
> Subject: Re: [GRASS-dev] non-zero return code -11 from v.in.ogr in python
script
> On Wed, Jun 13, 2018 at 11:34 AM, Stefan Blumentrath <
> > Hi,
> > On a GRASS 7.4 installation from ubuntugis-unstable I get a “non-zero
return code -11” error when I try to import data from PostGIS using
v.in.ogr in a ython script.
> > Looking at the post here:
> > https://lists.osgeo.org/pipermail/grass-dev/2016-March/079614.html
> > it seems to be a version conflict but I double-checked and the GDAL
version on the system is exactly the one GRASS 7.4.0 on ubuntugis-unstable
is built against.
> > This error is for some reason not popping up every time I run the
script but somewhat unpredictable...
> > Does anyone of you have a suggestion on how to trac the cause for the
problem? Can it be linked to temporary files or NFS write instability…?
> You need to get the exact options that cause v.in.ogr to fail, then run
it in the CLI with gdb and get the backtrace
> gdb --args v.in.ogr in=... out=...
> GRASS needs to be compiled with debugging enabled, i.e. the CFLAGS must
contain -g. See also the GRASS wiki page on debugging [0]
> Markus M
> [0] https://grasswiki.osgeo.org/wiki/GRASS_Debugging#Using_GDB
> > Thanks in advance for any hint…
> > Cheers
> > Stefan
> > grass-dev mailing list
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180614/777b48bb/attachment.html>
