[GRASS-dev] [GRASS GIS] #3595: d.rast.edit: entering new value requires ENTER to be hit, GUI should be changed
GRASS GIS trac at osgeo.org
Sun Jun 24 02:42:11 PDT 2018
changed
 Reporter:  neteler      |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.4.2
Component:  wxGUI        |    Version:  svn-releasebranch74
 Keywords:  d.rast.edit  |        CPU:  Unspecified
 Platform:  Unspecified  |
 d.rast.edit requires ENTER key to be hit when entering a New value". This
 is surprising and undocumented (and not obvious at all from the GUI).
 Suggestion: change GUI behaviour to e.g. "zscale" value management of
 r.slope.aspect (or any other module).
 In addition, two errors come up when using d.rast.edit:
 # at startup:
 scripts/d.rast.edit:211: wxPyDeprecationWarning: Call to deprecated item.
   self.SetVirtualSizeHints(50, 50)
 # when saving
 WARNING: No data base element files found
Ticket URL: <https://trac.osgeo.org/grass/ticket/3595>
