[GRASS-dev] [GRASS GIS] #2998: m.nviz.image fails with X Error BadValue integer parameter out of range for operation
GRASS GIS trac at osgeo.org
Fri Jun 29 23:39:53 PDT 2018
operation
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:  7.2.4
 Component:  LibOpenGL   |    Version:  svn-trunk
Resolution:              |   Keywords:  m.nviz.image, NVIZ, 3D, GLX,
                         |  X_GLXCreateContext, g.gui.animation
       CPU:  x86-64      |   Platform:  Linux
Comment (by hcho):
 r72939 should fix this issue. Indirect rendering is disabled by default
 since Xorg 1.17. Nviz now uses direct rendering. If we need to support
 indirect rendering, we can add an environment variable later.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:11>
