[GRASS-dev] [GRASS GIS] #774: i.rgb.his, i.his.rgb, d.his support for >8 bit
trac at osgeo.org
Fri Mar 2 08:39:44 PST 2018
Reporter: hamish | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.4.1
Component: Raster | Version: svn-trunk
Resolution: | Keywords: i.rgb.his, i.his.rgb, d.his
CPU: All | Platform: All
Changes (by neteler):
* version: svn-develbranch6 => svn-trunk
Comment:
Replying to [comment:17 Nikos Alexandris]:
> The statistics in https://trac.osgeo.org/grass/ticket/774#comment:13,
show that going from either an 8-bit or 16-bit RGB to HIS and back to RGB,
figures are not scrambled. Some rounding applies, as exemplified in the
same stats above. Even visually, I confirmed (not documented here) that
the old and the new versions perform the same.
This sounds very promising.
> It will break i.pansharpen, unless i.pansharpen treats intensity ranging
in [0,1].
Would it be hard to add that to i.pansharpen?
> Nevertheless, another set of tests would be certainly good to have to
confirm the correctness of the new version.
I'd suggest to "svn move" it from sandbox to addons for wider testing with
g.extention.
Ticket URL: <https://trac.osgeo.org/grass/ticket/774#comment:18>
