[GRASS-dev] [GRASS GIS] #3511: [patch] v.buffer: allow squared buffers around points
trac at osgeo.org
Mon Mar 5 13:08:01 PST 2018
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.4.1
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.buffer squared buffer
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:1 mlennert]:
> Replying to [ticket:3511 mlennert]:
> > The attached patch implements squared buffers around points.
> Forgot to explain: with the patch, v.buffer should create square buffers
around points if the -s flag is set.
Currently v.buffer always uses Vect_point_buffer2() for points, but the
Vect_*_buffer*() functions might disappear at some stage because they are
not working properly (apart from point buffering). Therefore it might be
safer to add this functionality to v.buffer directly.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3511#comment:2>
