[GRASS-dev] pygrass: How to allow Ctrl-C to stop all subprocesses of GridModule
Nikos Alexandris
nik at nikosalexandris.net
Fri Mar 9 01:17:33 PST 2018
* Moritz Lennert <mlennert at club.worldonline.be> [2018-03-09 09:16:01 +0100]:
>Hi Nikos !
>Am 9. März 2018 09:01:25 MEZ schrieb Nikos Alexandris <nik at nikosalexandris.net>:
>>* Moritz Lennert <mlennert at club.worldonline.be> [2018-03-08 15:05:46
>>+0100]:
>>>And another question on GridModule:
>>>For the same module using GridModule to split the task of edge
>>>detection in a raster map into many parallel tasks, when I want to
>>>stop the module run using Ctrl-C I get tons of
>>>Process PoolWorker-315:
>>>Traceback (most recent call last):
>>> File "/usr/lib/python2.7/multiprocessing/process.py", line 267, in
>>>_bootstrap
>>>_bootstrap
>>> self.run()
>>> self.run()
>>> File "/usr/lib/python2.7/multiprocessing/process.py", line 114, in
>>run
>>run
>>> self._target(*self._args, **self._kwargs)
>>> File "/usr/lib/python2.7/multiprocessing/pool.py", line 102, in
>>worker
>>worker
>>> task = get()
>>> File "/usr/lib/python2.7/multiprocessing/queues.py", line 374, in
>>get
>>> task = get()
>>get
>>> racquire()
>>> racquire()
>>>KeyboardInterrupt
>>>and cannot stop the module, even when flooding the input with Ctrl-Cs.
>>>Any hint how to allow Ctrl-C to stop all subprocesses ?
>>>Moritz
>>Moritz, could it be a case related to the ones mentioned in
>>https://stackoverflow.com/a/1635084/1172302
>>https://stackoverflow.com/a/11816038/1172302
>Related yes, but AFAIU GridModule uses multiprocessing, not multithreading. I think it should be possible to modify something in the GridModule class so that it interrupts, but not sure about what exactly (apparently this is specifically a problem in Python 2. In Python 3 it should happen automatically IIUC.
Right. This https://stackoverflow.com/a/35134329/1172302 should be,
however, directly related. However, not portable, as per a comment.
How about this one: https://stackoverflow.com/a/44869451/1172302 (July
2017)? See
also
http://jessenoller.com/blog/2009/01/08/multiprocessingpool-and-keyboardinterrupt.
Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180309/63cac3e0/attachment.sig>
