[GRASS-dev] [GRASS GIS] #3511: [patch] v.buffer: allow squared buffers around points
GRASS GIS trac at osgeo.org
Mon Mar 12 01:48:31 PDT 2018
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.4.1
 Component:  Vector       |    Version:  svn-trunk
Resolution:               |   Keywords:  v.buffer squared buffer
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:4 mmetz]:
 > Replying to [comment:3 mlennert]:
 > > Replying to [comment:2 mmetz]:
 > > > Replying to [comment:1 mlennert]:
 > > > > Replying to [ticket:3511 mlennert]:
 > > > > > The attached patch implements squared buffers around points.
 > > > > Forgot to explain: with the patch, v.buffer should create square
 buffers around points if the -s flag is set.
 > > > Currently v.buffer always uses Vect_point_buffer2() for points, but
 the Vect_*_buffer*() functions might disappear at some stage because they
 are not working properly (apart from point buffering). Therefore it might
 be safer to add this functionality to v.buffer directly.
 > > Please check the attached new patch.
 > The patch looks and works fine, please commit.
 Done in r72353.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3511#comment:5>
