[GRASS-dev] Is automatic compilation of addons currently working ?
Markus Neteler
neteler at osgeo.org
Tue Mar 13 04:21:03 PDT 2018
On Tue, Mar 13, 2018 at 11:20 AM, Martin Landa <landa.martin at gmail.com> wrote:
> 2018-03-13 10:22 GMT+01:00 Moritz Lennert <mlennert at club.worldonline.be>:
>> At https://grass.osgeo.org/addons/grass7/logs/ I see "logs generated Mon, 29
>> Jan 2018".
>> This seems to lead to the fact that recently added addons are not in the
>> list of addon manual pages...
(FWIW, here is the procedure
https://trac.osgeo.org/grass/browser/grass-addons/tools/addons/README.txt
> not sure why cronjobs stopped working. I run script manually for now.
> But we need to investigate if the cronjobs starts to work. Basically
> in less than 30min the logs/manual should be updated after each
> grass_addons commit.
Perhaps a change in the trac server does no longer trigger the job at your end?
Markus
