[GRASS-dev] [GRASS GIS] #3509: g.region grow with negative number limited because of top and bottom
trac at osgeo.org
Tue Mar 13 17:28:06 PDT 2018
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 7.6.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: grow, shrink, g.region, expand
CPU: | computational region, extent, 3D
Unspecified | Platform: Unspecified
Comment (by lucadelu):
I create this "workaround", I don't think a true fix could exist. It is
something like if a user decide to set the Top smaller then Bottom.
The same problem could append with extent
g.region -p raster=elevation
g.region nsres=13480 ewres=14980 rows=1 cols=1 -p
g.region -p grow=-1
ERROR: North must be larger than South
Should we also try to fix something like the error above? Or we should
just improve the output message?
I think this is not a bug but a user error or misunderstanding.
What do you think about the attached patch?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3509#comment:2>
