[GRASS-dev] Weird bug in r.sun: command hangs forever for some day of the year
Pierre Roudier pierre.roudier at gmail.com
Thu Mar 15 15:43:45 PDT 2018
The problem seems to be fixed in the grass7.5-svn I last checked out from
SVN and compiled about 3 weeks ago.
Hum...
On 16 March 2018 at 11:22, Pierre Roudier <pierre.roudier at gmail.com> wrote:
> OK, something additional I noticed: I obviously wrapped the calculations
> for each day of the year in a script.
> Somehow, it seems I can re-process manually a day that was hanging during
> the script.
> Below is the script I used:
> for DAY in $(seq 1 365);
> do
>     DOY=$(printf "%03d\n" $((DAY)))
>     echo "Processing day ${DOY} ..."
>     eval `g.findfile element=cell file="glob_rad_${DOY}"`
>     if [ ! "$file" ]
>     then
>         r.sun elev=dem_1k aspect=aspect_1k slope=slope_1k day=$DAY
> glob_rad=glob_rad_${DOY}
>         sleep 15
>     fi
> done
> On 16 March 2018 at 11:04, Pierre Roudier <pierre.roudier at gmail.com>
> wrote:
>> Hi,
>> Just bumped into the weirdest bug in r.sun on GRASS 7.4 as installed from
>> the Ubuntu repository.
>> I am using r.sun in Mode 2 to compute the daily average global radiation.
>> The GRASS location is using EPSG:3031: this is data over the entire
>> Antarctica.
>> For some specific days, that seem to be in winter, when most of the
>> continent doesn't recieve any solar radiation, the command would hang
>> forever at 9%:
>> For example I had to kill this command:
>> [Raster MASK present]
>> GRASS 7.4.0 (modis_lst_2015):/media/pierre/1TB_ext4/code > time r.sun
>> elev=dem_1k aspect=aspect_1k slope=slope_1k day=159 glob_rad=glob_rad_159
>> --o --verbose
>> Number of threads <1>
>> Mode 2: integrated daily irradiation for a given day of the year
>> Using Linke constant: 3.000000
>> Using albedo constant: 0.200000
>> Using slope map <slope_1k>
>> Using aspect map <aspect_1k>
>> ^C 9%
>> But for the day before and the day after the command was successful in
>> less than a minute:
>> elev=dem_1k aspect=aspect_1k slope=slope_1k day=160 glob_rad=glob_rad_160
>> --o --verbose
>>  100%
>> real    0m30.019s
>> user    0m29.602s
>> sys    0m0.372s
>> It also happened on day 151... I'm a bit stuck, so any pointers would be
>> appreciated.
>> Cheers,
>> Pierre
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180316/b57ee536/attachment.html>
