[GRASS-dev] Brainstorm about new GRASS GIS startup
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Mon Mar 19 14:34:58 PDT 2018
Hi Moritz,
Looks nice.
The "Open into a predefined lat-long location but give information message" option seems less involved than the first. Thus if "simplification" is the aim, I would probably continue in that direction. Having lots of choices already at the first startup-screen is probably counter-productive.
An example location can be helpful for new users to get the concept in any case. And I would suggest to start the predefined lat-lon location in a mapset other than PERMANENT...
However, the placement of the GISDBASE directory is also an important choice, that is not covert by the current mockups. So, maybe a more wizard like approach might be worth a thought? Right after choosing the GISDBASE dir, there can then be a "let me explore in sample project" button (together with the other main buttons from the first alternative maybe).
In any case, I would also consider a "don`t show this message again" checkbox together with a grassrc setting...
And users should be informed in advance before additional data is downloaded.
Cheers
Stefan
P.S.: A less relevant side note: Personally I rather translate mapsets with "projects" (but that is not very accurate either)...
-----Original Message-----
From: grass-dev [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Moritz Lennert
Sent: mandag 19. mars 2018 21.48
To: grass-dev at lists.osgeo.org
Subject: Re: [GRASS-dev] Brainstorm about new GRASS GIS startup
Le Mon, 19 Mar 2018 21:23:14 +0100,
Moritz Lennert <mlennert at club.worldonline.be> a écrit :
> Hi everyone,
> At the code sprint in Bonn we (including virtually with Helena, Anna
> and Vaclav) discussed about possibilities of making the GRASS GIS
> startup more newbie friendly. This raises several issues concerning
> what we should do concerning possible default startup location,
> default GISDBASE, etc.
> I started a wiki page to collect ideas and reflections:
> https://trac.osgeo.org/grass/wiki/New_Startup
For better wiki structure, the page was renamed to:
https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/New_Startup
Moritz
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
