[GRASS-dev] [GRASS GIS] #3520: colorize vector layers in GUI by default
trac at osgeo.org
Mon Mar 19 18:54:36 PDT 2018
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.6.0
Component: wxGUI | Version: unspecified
Resolution: | Keywords: vector, colors
CPU: Unspecified | Platform: Unspecified
Comment (by wenzeslaus):
I agree that the current default is not ideal. Preferred behavior probably
depends on the use case, but `-c` as default is quite different from what
everybody else does (so potentially it is unexpected): loading each vector
layer to map display with different single color versus different color
for each feature in the vector map/layer. I think it is a great checkbox,
just not sure if it should be enabled by default.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3520#comment:4>
