[GRASS-dev] [GRASS GIS] #3525: Removing the behavior of i.maxlik which add the output to input group
GRASS GIS trac at osgeo.org
Tue Mar 20 08:51:13 PDT 2018
 Reporter:  spareeth     |      Owner:  grass-dev@…
     Type:  enhancement  |     Status:  new
 Priority:  normal       |  Milestone:  8.0.0
Component:  Default      |    Version:  svn-trunk
 Keywords:               |        CPU:  Unspecified
 Platform:  All          |
 The final result from i.maxlik is added to input group by default. which
 in my opinion is strange. I dont know if there is any reason behind this
 behaviour.
 In the mapset nc_spm_08_grass7/landsat;
 i.group group=lsat7_2000_NW subgroup=lsat7_2000_NW
 input=lsat7_2000_10,lsat7_2000_20,lsat7_2000_30,lsat7_2000_40,lsat7_2000_50
 i.cluster group=lsat7_2000_NW subgroup=lsat7_2000_NW
 signaturefile=sig_cluster_lsat2000 classes=10
 reportfile=rep_clust_lsat2000.txt
 i.maxlik group=lsat7_2000_NW subgroup=lsat7_2000_NW
 signaturefile=sig_cluster_lsat2000 output=lsat7_2000_cluster_10classes
 reject=lsat7_2002_cluster_reject
 i.group lsat7_2000_NW -l
 group <lsat7_2000_NW> references the following raster maps
 <lsat7_2000_10 at landsat>
 <lsat7_2000_20 at landsat>
 <lsat7_2000_30 at landsat>
 <lsat7_2000_40 at landsat>
 <lsat7_2000_50 at landsat>
 <lsat7_2000_cluster_10classes at landsat>
 <lsat7_2002_cluster_reject at landsat>
 Would be better to remove this behaviour in future release.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3525>
