[GRASS-dev] [GRASS GIS] #3519: GUI: show computational region extent by default
GRASS GIS trac at osgeo.org
Tue Mar 20 12:07:29 PDT 2018
  Reporter:  martinl      |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  7.6.0
 Component:  wxGUI        |    Version:  unspecified
Resolution:               |   Keywords:  map display, comp extent
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by martinl):
 In [changeset:"72436" 72436]:
 #!CommitTicketReference repository="" revision="72436"
 wxGUI: set up default map display properties when new display is open
        add settings to show comp. region extent, see #3519
        (merge r72379, r72381 from trunk)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3519#comment:4>
